I just destroyed a Roland D-5 keyboard. What a piece of unrepairable
junk. Hopefully, the XP-60 is better built. I could not determine if
the XP-60 media uses 1.44MB or 720KB floppish. What is the make and
muddle drive that is stock for the Roland XP-60?
http://www.vintagesynth.com/roland/xp60.php>
I recently repaired a Korg DSS-1 with the traditional dead floppy disk
drive problem.
http://802.11junk.com/jeffl/Korg_DSS-1/>
If your XP60 requires a 720KB floppy drive, instead of the usual
1.44MByte floppy drive, you have to find one that has suitable jumpers
available. This might also help:
http://blog.retrosynth.com/archives/2005/08/fun_with_akai_m.html>
If you're lucky, the only jumper you'll need to move is the drive
select jumper, usually labeled DS0, DS1, DS2, and DS3. The common PC
drive is set to DS1. Most of the synthesizers I've played with use
DS0.
Oddly, all of the five or so synthesizers I've fixed that had floppy
drives have all had dead floppy disk drives. My guess(tm) is that
they die from static discharge while shoving the floppy into the
drive. That's what killed mine. I've thought of electroplating the
plastic front panel of the drive with metallic chrome or other metal,
to discharge the static before the floppy enters the drive.
Jeff Liebermann
[email protected]
150 Felker St #D
http://www.LearnByDestroying.com
Santa Cruz CA 95060
Skype: JeffLiebermann AE6KS 831-336-2558
