Hello there!
I'm wondering if someone could help me adapt a circuit from this website:
http://imakeprojects.com/Projects/rock-band-dual-bass-drums-controller/
This circuit takes an off/on signal from two Rock Band drum pedals and, essentially, allows them to NOT block one another if one of the pedals is down. These pedals work by magnetic switch.
Unfortunately, I need this circuit to work with the Guitar Hero pedal, which works with a piezoelectric sensor which, from what I can tell, outputs a small voltage spike when the pedal is pressed.
Does anybody have any idea how I can modify the circuit to accept the sensor inputs and still produce the circuit's output?
OR
Can I change the sensor output to create an on/off signal the circuit can use?
THANK YOU BIG TIME IN ADVANCE!!
OR
