Supercap2F submitted a new Showcase Item:
Robot Sumo Project
Read more about this showcase item here...
Robot Sumo Project
Hey Everyone!
This is my 1.5-2 year project that I have referenced to a couple times. I thought I would start a project log, since I'm kind of proud of it. Unfortunately I'm almost done with it, so this may be a rather short thread. Here it is still in construction:
I will upload some more photos later.
Some more photos:
The main boards with the ICs not on yet:
Yesterday I did some more work on it and got the front IR sensors mounted.
Did some more work on it the other day. Got the side IR sensors mounted. And a lot of wires hooked up. I hope to get the back IR sensors hooked up today. The Front:
The side with the sensors distance adjust pots:
My work space (kind of messy):
Well I got a lot more done today then I thought I would! I mounted the back sensors, and hooked up just about everything I could before I mount the main boards. I got the tires glued on to.
Well I just finished it. Got everything hooked up and the battery mounted. Then I flipped it on and IT DIDN'T WORK!!!!!!! It didn't even try to work. Nothing turned on at all. And also the battery are getting kind of hot.
I guess I have got a long day of trouble shooting tomorrow.
Update #1: YAY!! I just tested one of the main boards and the + and - terminals are a dead short! That explains why the battery was getting hot and why nothing worked. I just hope thats all thats wrong with it. I will find out tomorrow!
Update #2: Well I got it kind of working. The problem was I did not have the microcontroller hooked up to each other. And there was a small piece of wire stuck between two capacitor pins. Right now it turns in circles and some of the edge sensors don't work. Hopefully that will be an easy fix.
YAY!! I just...
