Richard Cassano
I have a new Air-X Marine wind generator installed aboard a sailboat. The
unit is mounted on a ten foot pole and is wired as per the instruction
manual directly to the 630 amp hour battery bank. All works great. the wind
generator is putting out plenty of charge, however, the RFI/EMI picked up by
the SSB radio, (Icom M-802) is extreme. The RFI noise is across all bands
and makes the radio unusable. I can shut off the Air-X with the optional
switch but I was wondering if anyone can confirm that this is a common
experience with other owners of the Air-X Marine wind generator. If so, I
will not look further for a solution. If I am the only one with this problem
than I can assume the RFI is a result of some defect in the electronics. One
Note: the backstay antenna is about five feet away from the wind generator.
Thanks.
Thanks.
