I've been trying to build some prototype indoor positioning circuit systems. I've read about some ultrasonic positioning circuits which measure the delta between an ultrasonic signal and an RF signal - these seem to be remarkably accurate however the inability of the ultrasonic signal to tolerate obstacles is an issue for the application I have in mind.
The biggest difficulty of rf time of flight is the synchronisation between transmitter and receiver. however I've had an idea for what I hope would be an answer to this issue.
if a moving robot were to transmit an rf signal and a stationary node were to reflect this signal at a different frequency then if the robot could detect this signal if would be able to tell the time difference between sending and receiving the signal. The time difference would be made up of two component 1. The time delta due to the stationery node (time between receiving and reflecting the signal) and 2. the time due to the signal having to travel the distance. The time delta due to the reflector node should in theory be constant and the time to travel through the air should be variable depending on the distance from the reflector node.
There should be no synchronisation errors due to both sending and receiving being down by the same device - provided that the 'processing time' by the stationary node stays constant this should be able to measure distance
Please let me know what you all think of this idea
Thanks,
Will
Thanks,
Will
