hevans1944
Hop - AC8NS
Years ago, in the 1950s, I was briefly attracted to the fixed-wing, flying, model aircraft hobby. Back then it was all about balsa wood air-frames, and fabric-covered fuselages, wings, and control surfaces, said fabric painstakingly applied, doped, painted, and affixed with decals before the model was deemed airworthy. It generally took several months to complete a model before it was ready for its first flight. Of course the highly toxic fumes from the model dope made it all worthwhile... probably. If you survived the brain damage.
Radio control was possible with the larger models, but very expensive and prone to interference from other nearby RC operators. So most of the non-RC "flying" was done in a circle, using a pair of thin steel cables attached to the port-side wing(s) to tether the aircraft to the operator on the ground, who then controlled the pitch axis of the flying model by varying the differential tension on the two cables. This was the so-called U-Control, patented, method of model airplane flying. In skilled hands it allowed the operator to perform some amazing aerobatic maneuvers within the limitations of flying in a circle. Ho hum. Boring! Plus I never did get the "hang" of how to fly my little Spirit of St. Louis, 0.049 cu.in. glo-plug powered, single-engine model airplane using U-Control lines. Heck, most of the time I had trouble even getting the engine started.
It is all so different today. High-speed, brushless, DC motors and lithium polymer (LiPo) batteries have made liquid-fueled engines virtually obsolete. Inexpensive plastic kits with on-line DIY instructions and Asian RC electronics have brought Unmanned Aerial Vehicle (UAV) capability to the common man. With modern electronics controlling the flight, you don't even have to know anything about flying! What's not to like? Just peel off twenty or thirty Benjamins and purchase a ready-to-fly quad-copter drone with Forward Point of View (FPV) video camera and you are off and running (or up and flying). Be sure to register your drone with the FAA, always fly with the drone in your direct, unaided eyeball, line-of-sight, never fly more than 400 feet AGL (Above Ground Level), and never faster than 100 mph.
The purpose of this thread is to discuss the role (if any) of amateur radio in extending the range and reliability of Radio Controlled (RC) flight. One can apply to the Federal Aviation Administration (FAA) for an exemption to the "line-of-sight" rule, but if granted that still leaves the problem of how to implement a reliable radio link over extended distances, beyond the line of sight, where there may be and probably are obstacles along the way. While it may be as simple as increasing transmit power levels, which a ham license allows, it may also be more complicated, requiring frequency diversity, or more bandwidth to accommodate sophisticated error detection and correction, or spread-spectrum techniques to "punch" the radio frequency signal through between the operator on the ground and the aircraft in flight.
We are not interested in discussing the state-of-the-art capabilities of military platforms such as the Predator drones or Global Hawk remotely piloted vehicles (RPVs) with their satellite down-links and other airborne communication networks. Nor are we interested in the low-power, unlicensed, low-end of the range of civilian users. What I would like to see this thread address is the synergy that can be obtained by merging FCC-licensed amateur radio capabilities with modern RC flight control capabilities applied to FAA-licensed drones. The goal is to advance the state-of-the-art and the enjoyment of both hobbies, safely and legally.
Electronics Point is an eclectic community with a broad range of experience and capability. We are not just all about LEDs and PWM motor control, although there is nothing wrong with that. There are knowledgeable posters here that I have not seen in awhile, so maybe a discussion in this thread will revive their participation...
Hop (AC8NS)
Hop (AC8NS)
