MRW
I was going to the appliation note for the TEA5768 and I can't seem to
figure out how they came up with this matching network:
http://img391.imageshack.us/my.php?image=tea5768rfmatchckt1bd.jpg
The image shows 3 pin connections to an LNA. The application note
states that "the input impedance of the LNA is (100 ohm || 4pF) each
pin (referenced to ground)." It also mentions the following:
"The antenna-input signal is fed into the balanced FM-RF inputs (pin 35
and pin 37) via a RF matching impedance circuit. A series capacitor,
two parallel capacitors and a coil (L1) build this circuit. The coil
used in this circuit should have a minimal Q factor of 30. Its
tolerance is ± 5%. Together with the impedance of the LNA, the RF
matching circuit forms a low Q band pass filter."
Can anyone give me any tips on how they came up with this matching
network?
I tried to do the following.
1). Found the input impedance by using 88 MHz as my frequency. I picked
this because the frequency response chart showed a peak at this
frequency.
However, I cannot seem to proceed after that because I get confused by
the two RF inputs. The matching networks that I've worked with only
assumed one RF input.
Can I just ignore the two RF inputs and combine the two capacitors
(27pF and 47pF) in parallel then have this total capacitance be in
parallel of the 120nH inductor?
Thanks!
network?
frequency.
Thanks!
