Joerg
Hello Ken,
That's how I define it.
Not really. In an RF amp such protection schemes are typically much
slower than the slew rate of the amp, usually by orders of magnitude.
That is one reason why, for example, an over-voltage condition after an
antenna cable break blows the final transistors. The protection circuit
isn't fast enough to curb power.
It is possible to design true feedback that sets the impedance as you
describe but I have rarely seen that in RF gear. Usually there is just a
fwd-ref bridge plus a current shunt and those signal to a uC or (slow)
discrete parts.
Not the short term "true" output impedance. In this quite typical case
the bridge and shunt signals went into multipliers (fast), then into a
micro controller (really slow compared to the RF). Only after the uC had
executed its respective code would the protection scheme do something.
Probably in the order of milliseconds.
Actually, the shunt signal also had an override path, curbing power
while bypassing the uC (still slower than the RF stage though). But this
only means that the output impedance was curbed to a lower limit for the
high power range. When operated at, say, 20% power it wouldn't do
anything to prevent you from connecting that 30ohms load versus 50ohms
nominal.
It depends on how you define "output impedance". If you define it as the
variation in output voltage vs load current, the impedance is as I stated.
The protection reduces the output voltage when the load current increases
therfor, it is part of the output impedance of the circuit.
discrete parts.
You changed the output impedance by those modifications. If you hadn't
made them, the output voltage would have been less at that load current.
nominal.
