Ok, I watched several videos and think I'm getting closer to figuring out the formula for the inductor value:
Assuming Io is current draw from the decoder and receiver measured in amps, the total is .0064 amps.
I think "fsw" is 70 if I pull pin 3 to ground.
If I supply the circuit with 6 volts...
L= (6-3.3)/(.0064 x .1) x (3.3)/(6x70)
L= (2.7 / .00064) x (3.3 / 420)
L= 4218.75 x .007857
L = 33.147
Is this correct or am I way off? If correct, what unit of measurement is 33.147? Also, if correct, how do I select the value of the special diode?
L = 33.147
