daestrom
Gìmmìe Bob said:Interesting stuff. Thanx for the information, especially the heat exchange
method. I have never heard of this technique before (never looked
either...LOL)
Some points noted:
-Your heat exchanger measurements does not live up the theory (call in
ineffieciencies maybe due to size etc.)
Nick is hoping for >85%. But the particular GFX I have (S4-60) is more like
a two-pass shell. It has two parallel coils of freshwater to reduce the
freshwater pressure drop. The two coils are arranged in series on the waste
stack. This is not ideal as far as heat-exchanger theory though. The warm
waste water is cooled by one coil then falls to the inlet of the second
coil. So the second coil "see's" less delta T. Then the freshwater from
each coil is mixed together. But my particular situation I couldn't
tolerate the pressure drop of running the coils in series, it would be too
much. :-(
For the G3-60, with flow around 1.5 gpm, the effectiveness is supposed to be
about 65%. I'm only able to measure between 45 and 55% depending on the
exact day, inlet temperature and what not. So no, I'm not getting full
effect. But it is saving me money and has almost paid back already. So I
think it was worth it.
- Your NG bill must be much higher than mine I would have to do some
research but I doubt my hot water bill was much over $135 Canuck for the
year including the rates etc. The rental was more though...LOL Then again
I
cannot separate my heating from the HW very well as I have a gas stove
etc.
I may be basing ideas on old prices. Must rethink that one.
Well, you may not use as much hotwater as my family. I have a family of
five and as I've mentioned before, my adult son is a bit of a 'water
buffalo' and takes long showers. Since the heat exchanger represents a
'capital investment', and the dollar savings depends on the amount of hot
water one uses, it may not be right for everyone. But it does seem to be a
largely ignored part of home energy use.
- Last thing I heard , he was talking a barrel at the end of the greywater
drain as a heat exhanger. I had suggested the "in-pipe" method and thought
he forgot it due to mechanical logistics. (maybe I haven't followed that
closely) He was also feeding it into his hot water heater as a preheater.
This method seems much more logical in the physics dept.
The GFX actually gets better performance than a traditional shell and tube
or tube-within-a-tube type. This is due to the fact that waste water
spreads out in a very thin film (thinner than the boundary layer found in
traditional flooded shell). Much thinner means high film coefficient for
rapid heat transfer. Even though the water is only in the unit for 2-3
seconds as it falls through.
But it has the draw back that when you shut off the water, the water
currently in the tubing just stops and losses heat to ambient. And 'batch'
processes like filling a tub with warm water, then emptying it out 15
minutes later doesn't do *anything* in the GFX. If there isn't any
freshwater flow when the warm water goes down the drain, you just heat up a
'slug' of water in the tubing but don't get to use it. Unless you fill and
drain the tub several times, and only use one 'slug' worth of water at a
time to fill the tub.
Nick's been trying to come up with a design that would overcome this
limitation. By having a heat exchanger that can hold up a typical 'batch'
of hot water, he hopes to recover the energy in it at a later time when
freshwater flows. But with improvements in 'batch' mode, it may lose some
effectiveness in continuous-flow mode.
- I like the "water has to prewarm the pipes" idea. I stated erlier that I
wait about 1.5-2 minutes for my hot shower each morning.
- I take a 10-12 minute shower each day, washing my hair and shaving too.
If
you use a blade, get a mirror in the shower and you will never shave in
the
sink again. Does a much cleaner/nicer job on your face.
Yeah, my brother has told me that. But I've had a beard for 27 years now
and don't see that changing
daestrom
