I need to power a small 20mm mini 5v fan. I have a 5v mean well power supply but I want to use a resistor to lower the voltage to 2.80v. I tested the fan at 2.80 volts (with a vaiable power supply) and it was the quietest while giving enough air. Is it possible to just put a resistor before the fan to lower the voltage to 2.80v? Everything online talks about using a resistor for LED's. I don't get it, can you only use a resistor with constant current?
My power source is 5v 6A
My mini fan is rated at 5v .150 but I want it to run at 2.80v (Its draws around 50mA at that voltage according to my variable ps)
