Hello,
i have a burnt resistor on my circuit board which i cant identify the two middle color code... when inspect the circuit board, there are several resistors with the same first and last color,. so i assume that the burnt resistor is the same as the other resistor.
Now, can i replace that resistor with higher resistance ohms? the color i get from the other resistors are
Brown-Violet-Yellow-Gold which is 170k Ohms 5%... is it ok to replace this with the one with higher resistance? what Ohms can you suggest which will be good as replacement for 170k Ohms?
Thank you
Neil
Thank you
Neil
