Hi guys.
As much as I like figuring things out for myself, this one has got me beat!
Right. This is probably very basic for nearly all of you but I'm trying to wire up some LED DRLs on the car with some of those pretty LED illuminated latching switches..........
..........like these
Now, these are supposed to be for use in 12v applications but when I have applied my light testing battery box with a 9v battery inside, the LED's inside of the switch blow!
So I thought, "OK, resistor!". Great! A little dimmer, but doesn't blow the switch illumination. Fine.
So then I mock up the rest of it by following this..........
So I've got my LED light strip positive to NC1 / + / brown,
LED negative to - / ground / black,
9v battery positive to C1 / red with resistor in line,
9v battery negative to - / ground / black
Press the latching switch on, on comes the illuminated switch LED and on comes the LED's on the strip that I was aiming to switch on. Great, It all works!
The issue I have is though (and I know most of you know exactly what I'm going to say), even though I have over come the issue of blowing the LED in the switch by placing a resistor in line, now my LED's on the strip are not bright enough :-C
So. Firstly let me just be clear, am I wired up correctly?
And secondly, how can I stop the LED in the switch from blowing at 12v but keep the LED's on the strip as bright as they should be??
There is a question I want to ask about wiring up so that maybe the LED in the switch is constantly on but dimmer/brighter when the button is pressed off/on respectively. If this can be answered in the same swift stroke, then I will be even more so appreciative
Thanks in advance for any useful info guys
