Resistor Colour Codes
Richard Harris
I have a resistor that is showing up as 56.0 Ohms on a multimeter but the
colour code seems to say 560 Ohms.
Green Blue Black Gold Brown
5 6 0 ?? 1% Tolerance
What does the gold mean?
Thanks for ya time guys.
Anthony Fremont
Richard Harris said:
Maybe it's really Brown and not Black for the third band?
+/-5%
Charles W. Johson Jr.
+/-5%
Multiply 56 by 10 raised to the Zero power , wich is 1 not 10.
Charles
Anthony Fremont
I know, but I think of it like the third digit is just the number of
zeros. Six to one, half dozen.....
F
Fred Abse
Green Blue Black Gold Brown 5 6 0
Green - 5
Blue - 6
Black - 0
Gold - multiplied by 10^-1 ie. 0.1
Brown - 1%
Hence 56 ohms.
That's the way it's done with five band resistors for values below 100
ohms
Divide by 10 (multiply by 0.1)
Jamie
Richard said:
codes are correct.
third band is your multiplier., this would make the
R 56 Ohms. 0 meaning no zero's after 56. 1 meaning 1 zero
which would be a brown ring how ever,
the gold band is your +/- 5% accuracy of the marked
reading.
the brown band, because it comes after the tolerance
reading normally used for quality and other markings.
you make see at times were you only have 2 color bands
and then a gold or Silver band, this is a fraction multiplier.
gold being X 0.1 of the first 2 digits, and silver being
x 0.01 etc./
you make also see another gold/silver band following it that
would then indicate the tolerance.
there are in some cases for more precise values 4 bands for
R value and then the Multiplier. you will know when you have one
of these due to the fact that gold/silver band will not appear until
after 4 color bands. R,R,R,M,T instead of the R,R,M,T
etc..
hope that helped some.
Jim Douglas
I always put em on the meter cause I can't see very good anymore, even with
lighted magnifying glass!
Robert Monsen
Capacitors are also numbered with this annoying scheme. A cap numbered
xyz is xy*10^z pF. A 100 cap is a 10pF cap. I would have prefered strict
scientific notation (which would have allowed 10ths of pF), but it was
probably invented before the widespread adoption of that notation.
Inductors also have the same numbering scheme, but their numbering is in
uH, not pF. Ugh. Inductors sometimes have the color bands to indicate
their values.
Regards,
Robert Monsen
"Your Highness, I have no need of this hypothesis."
- Pierre Laplace (1749-1827), to Napoleon,
on why his works on celestial mechanics make no mention of God.
Robert Monsen
I also do that on occasion. I'm partially color blind, so greens and
reds are 'weak' for me. Thus, I have issues with browns and reds looking
suspiciously similar. Unfortunately, the size of the colored area seems
to be a factor in whether I can recognize it, so while I can tell
stoplights with ease, I can't tell red from brown on resistors. I use
one of those big magnifying glasses too, and that helps, but keeping the
parts in separate labeled bins helps more.
Unfortunately, if I happen to drop a resistor into the wrong bin, I
often can't tell until something either doesn't work as expected, or
gets hot.
Such is life.
Regards,
Robert Monsen
me
that's:
5 6 0 1/10 1% Tolerance
for 560/10=56.0 +/- .56 ohms. A "precision" resitor.
Bob Masta
One of the guys where I used to work found that
replacing the cool-white fluorescents with daylight
balanced versions made a *huge* difference in
being able to tell red from brown on those 1%
resistors with blue bodies. Worked great, and
made it seem like perpetual sunrise in the lab
(which had no windows).
Bob Masta
dqatechATdaqartaDOTcom
D A Q A R T A
Data AcQuisition And Real-Time Analysis
www.daqarta.com
K
Kitchen Man
I think of the third color as "number of zeroes." For instance,
Yellow-Violet-Red is 4-7 plus two zeroes, or 4.7K. Other posters are
correct that the third band is a power of 10 multiplier, but for ease of
remembering and calculation, "number of zeroes to add" works for me.
The tolerance. I think gold is 1%. There are other color bands that
can creep in in different situations. For instance, a gold third band
means multiply by 10^-1, or one-tenth, which would make your resistor
5.6 Ohms if the third band were gold, not black.
