G
Gary Woodruff
Howdy all I have a resistor on a front panel tv control that has a 5
band color code of brn-blu-red-gold-grn. This resistor is not burnt but
measures 1.62K ohms. from the color code I would suspect 16.2 ohms. If I
replace the 1.62k with a 16.2 the set will not power on. If I put the
1.62k back in set powers and then shuts down after 5 seconds. There are
many posts that identify the front panel cb as the culprit.(circuit
board is no longer available from RCA). There are 4 or 5 resistors and 6
tact switches, and one cap on this board. this resistor is the only
component in the circuit with the on/off tact switch. My main confusion
is the color code and value of this resistor, am I missing something???
Gary
Gary
