No! I want this to make a dynamo-powered light for my bike with a few batteries keeping it lit when I stop at lights.
No what?
We are stating that the LED's don't need to be tested to determine how much current or voltage they consume because the information is in the data sheet.
If that's what you want to make, you need to determine a method of limiting the current to the LED so you don't burn it out. You also need to determine the appropriate battery or capacitor to keep it lit for as long as desired.
There is no need for your response, we gave you the details you requested, and nowhere above have you mentioned anything regarding a dynamo or battery operated device. What's more, is if you 'test' the LED you want to use and use your results to build your device, you are asking for trouble. The LED you are using could vary with time or temperature rendering
your test to be inaccurate which could cause the LED to fail. Once the LED is dead, and you order another you will run into the same problem.
Take *Steve*s information to heart and save yourself some trouble.
Just use a constant current source set up for a current less than or equal to 1500mA.
The voltage need not concern you other than for you to allow sufficient headroom for the regulator to operate.
