REQ: Reliable source for NiMH batteries (type 4/3A)
Jack
Hello,
I'm rebuilding a battery pack for a laptop. Can anybody recommend a
*reliable* inexpensive source for individual NiMH cells?
I need a total of 8 cells, type 4/3-A (1.2v, ~4000 mAhr), with solder
tabs.
Thanks!
-Jack-
[email protected]
To reply, use the 3rd planet's real name.
mike
Jack said:
Hello,
tabs.
Thanks!
-Jack-
[email protected]
DigiKey will sell them to you. Can't get more reliable than that.
Just in case you've never tried this before, there are issues.
Tiny differences in the thickness of the plastic coating can mean
the difference between fit and no fit when you stack up 8 of 'em.
I've had to peel off the heat-shrink and wrap them with packing tape.
That's risky even on a good day.
There's sometimes not room for the solder connection between cells.
You may have to spot weld 'em just to get the case back together.
Don't get me started on high-rate charge acceptance differences between
brands/types etc. Read the specs on the cells and understand the
charge termination methods used by your device.
YMMV.
At over $60 for the cells, it may not be worth rebuilding.
You DID emphasize *reliability* over cost...
mike
Return address is VALID.
Bunch of stuff For Sale and Wanted at the link below.
Toshiba & Compaq LiIon Batteries, Test Equipment
Yaesu FTV901R Transverter, 30pS pulser
Tektronix Concept Books, spot welding head...
http://www.geocities.com/SiliconValley/Monitor/4710/
Jack
...snip..
Yep, I can dig it... The existing cells are just over 18mm dia in
the wrapper, and 17mm unwrapped. The wrapper is heatshrink over a
rather heavy gauge cardboard tube.
Old ones in the pack are Sanyo HR-4/3A, and I see exact replacement
Sanyo cells selling for about 6-7 dollars ea at several vendors.
Vendor's specs: Sanyo, HR-4/3AU, 1.2V, 4000 mAhr, .670" X 2.640"
In my case, there's room for solder tabs. Width is critical, but I've
got several mm leeway, lengthwise.
Well, since I'm already looking at exact Sanyo replacements, I think
I'm safe there. In any case, I am quite aware of charging issues,
having worked with batteries and power supplies for many years. More
like decades? said:
YMMV.
Reread my original - When said "reliable," I meant a reliable dealer
and aid nothing about cost. I've had some bad experiences with
web-based vendors in the past.
The project is an old 100Mhz laptop I got for free which I want to
play around with in places that I wouldn't dare take my new $1200 2GHz
notebook. The lowest I've seen an OEM battery pack go for is $130,
and it's not really worth it for a "throwaway" computer. Half that
figure is low enough to make it worthwhile.
Anywhoos... thanks for the advise! I hadn't even thought about
Digikey for batteries. Since I'm about to make an order from them
anyway, I'll probably include the batteries (which will hopefully also
be Sanyo's).
-Jack-
[email protected]
W
Wild Bill
Formerly MCM Electronics, a large supplier of parts, components and all
kinds of commercial & consumer electronic gear.. located in Ohio IIRC, now
partnered with Newark under another name (Source One, or sompthin like
that).
Cheers
WB
H
Herbert West
that).
Arrgghhh!!! I'm googling with no luck. I shouldn't have to... John
said they have the batteries on sale so he knows how to reach them.
Unfortunately he didn't give any link or other way to get hold of them
in his reply. :(
Hey, John! Post the MCM URL! Thanks!
E
Eric R Snow
Hello,
tabs.
Thanks!
-Jack-
[email protected]
Greetings Jack,
Two sources I know of. First is Thomas Distributing, they sell Maha
batteries which have given me great service. The batteries and Thomas
Distributing. I don't know if they sell the exact batteries you want.
Second is Primecell. At www.primecell.com . They are a battery
rebuilding service. The rebuild batteries to better than original
specs. Good luck!
Cheers,
Eric R Snow,
E T Precision Machine
