Apple Boy
I have a pair of garage door safety beams that I would like to use as
some sort of beam detector in a project. Seems a waste to trash
these and design something new. The trouble is I can't figure out how
these suckers work!
Each one has only two wires going to it. I hooked up a 12v DC and
ground to each sensor and I got each to power up and start blinking
lights. But with only power and ground, how the heck does it send a
signal back to the computer? These are too old to be bluetooth.
I decided to hook up my logic probe to see if there was anything. No
pulses at all whether beam aligned or not.
Next I hooked up my DMM and set it to AC. Read 27v AC on each
sensor's 12v DC line. That's odd. I don't have a scope so I'm not
sure if there is some sort of AC signal being generated (but I would
like to have the $4700 Fluke pocket scope if you want to send one as
an xmas gift).
Finally I whipped out my camera to see if the IR sensor was glowing.
Sure enough it is.
I can't get these open, so I'm not sure what's inside. I already
applied Vulcan force and that failed - there are no visible
fasteners. Are these the impossible black boxes designed by NASA?
these suckers work!
an xmas gift).
Sure enough it is.
