Replace small mylar speaker
Hi everyone,
I am trying to repair this:
http://www.thinkgeek.com/interests/retro/8928/
It's a retro bluetooth headset from ThinkGeek.com. I replaced the rechargeable batteries and that works now (one was leaking)... but the small mylar speaker inside the earpiece is damaged. I can't seem to find the part online anywhere for sale.
It's a round 36mm 16-ohm 0.5 watt mylar mini speaker. It's about 4mm or so thick. Anyone have any suggestions? I came across a similar speaker at 8 ohms, but what adjustments would I have to make to use it? Also, would it sound alot worse at 8 ohms?
http://www.islproducts.com/componen...ers/59-mylar-speaker/81-mspk-36mm-round-8-ohm
Thanks,
Kosta
Given the low power of the device, the 8 ohm speaker may be a reasonable replacement.
You may notice that it is slightly louder, but you may be able to counter that with the volume control.
It may be less than optimal in other respects, but probably not enough to be noticeable.
If you're really paranoid you could wire an appropriate resistor in series with it, but that will reduce the volume somewhat.
