Hello All,
I am an electronics newbie with only a few projects under by belt. My current project it to create a target that when shot with a laser will fall over. Basically a solar cell which will trigger a transistor which will allow a 9 volt battery to power solenoid to knock the target over.
Right now I am trying to take simple night light circuit where a light comes on when its dark and replace the photo resistor with a solar cell. Since solar cells are a lot bigger target.
https://www.digikey.com/en/maker/blogs/2017/night-light-circuit-using-a-pnp-transistor
I want the light to go out when the solar cell is uncovered rather then when a photoresistor is uncovered. Every solar circuit I find on the internet wants to power the entire circuit with the solar cell or charge a battery with the solar cell. Neither of which I need for my project. I actually prefer having a regular old 9V battery in it.
I think its having a transistor connected to two different power sources that is throwing me. I have the Base of PNP hooked to the solar cell, the Emitter hooked to a 9 volt battery and the collector to the solenoid.
Any advice, or design direction I should explore.
