repeating character
Does anybody know how to fix a character
"{}]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]." that
keeps on repeating.?]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]. Like
that.]]]]] ]]]]]]].] it usually ]rep]eats off the cursor. i
have]]]]]]]]]]]]] a compaq presario laptop with windows xp.
thanks.]]]]]]]]]]]]]]].]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]
H
Homer J Simpson
Keyboard.
Charles Schuler
WD40?
WD40?
Can anything be done about a shorted out key? The bad key wont type
anything..except when it starts repeating. i have a laptop so cant get
a new keyboard..]]]]]]]]]]]]]]]]]]]]]]]]]]]. here it goes again.
thanks.
Charles Schuler
A drop of WD40 can't hurt. Try it ... what have you got to
lose???????????????????????????????????????????
bz
[email protected] wrote in @t69g2000cwt.googlegroups.com:
thanks.
1) Most laptops will accept an external keyboard. A USB keyboard should
work for most modern laptops.
2) bad keyboards can be replaced.
a) get a new keyboard from the company.
b) look for a keyboard for your model on e-bay
c) look for a broken laptop of the same model. Perhaps a broken
screen. You may be able to pick one up cheap.
3) some keyboard problems can be cleared up by putting the laptop on its
side and cleaning the keyboard well with a typewriter cleaning brush.
Good luck.
bz 73 de N5BZ k
please pardon my infinite ignorance, the set-of-things-I-do-not-know is an
infinite set.
[email protected] remove ch100-5 to avoid spam trap
PeterD
WD40?
a new keyboard..
Why not a new keyboard? What make and model is it?
thanks.
JANA
Try another keyboard.
JANA
_____
Ross Herbert
I would be surprised if the laptop in question didn't use a membrane
keypad. I haven't seen a membrane keyboard fail with a shorted key but
it may be possible. WD40 is the last thing you would use on this type
of keyboard.
Perhaps the OP can open up the laptop and determine (if possible) the
type of keypad it uses.
Anthony Fremont
I had an Armada that would generate "Backspace" randomly. Really
irritating. No amount of cleaning would make any difference.
Finally, I downloaded a remapping program and turned the backspace key off.
I then assigned F12 to send a backspace when pressed. Worked good except
when using remote desktop to control another computer. The F12 wouldn't
send a backspace on the other end. I can't remember the name of the program
though, sorry. I remember downloading two or three till I found one I
liked. It worked niceley.
You could start here:
http://www.snapfiles.com/get/KeyTweak.html
http://www.download.com/3120-20_4-0.html?tg=dl-20&qt=keyboard remap&tag=srch
contrex
Compaq Presario 2200 Keyboards cost £39 + VAT in the UK. Diiferent
models are different prices.
Jerry Peters
WD40?
thanks.
You keep saying that you can't get a new keyboard because it's a
laptop. This is most probably not true. On most laptops the keyboard
is removable; on the 2 DELL Latitudes I have it's almost trivial to
replace the keyboard. Try searching for your-laptop-model keyboard and
see if any vendors sell replacement keyboards for it.
Jerry
JW
It could attack the plastic. I use silicone spray for sticky keys on my
trusty IBM desktop keyboard. (20 years old and still going!)
More than likely this won't help the OP, though.
