Jeroni Paul
Hi group,
I repaired a PC power supply L&C model LC-235ATX. I found some
articles requesting some component values because this PS blows so
spectacularly. I'm posting these component values that usually blow
for future reference:
R2 4,7 ohm 3W
C7 22uF 25V
C5 C6 1uF 50V
R25 1K5
C26 10uF 50V
C25 47uF 50V
C35 2,2uF 50V
C24 100uF 25V
C23 100uF 16V
C36 10uF 50V
Q3 can be replaced by a BUT11AF
R21 4,7 ohm 3W
Mains fuse is 5A
Some of the mentioned capacitors were found high ESR so it is
recommended to check or replace them. If the fan is slow or noisy it
can be disassembled and lubricated removing the label and breaking the
plastic at the middle of where the label was.
R2 4,7 ohm 3W
C7 22uF 25V
C5 C6 1uF 50V
R25 1K5
C26 10uF 50V
C25 47uF 50V
C35 2,2uF 50V
C24 100uF 25V
C23 100uF 16V
C36 10uF 50V
R21 4,7 ohm 3W
Mains fuse is 5A
