If you get really bored you might see if you can hold a soldering iron on the leg of the ferrite bead, wait for it to degrade the epoxy, then use a couple pair of pliers to pull the lead out so you can stuff a new wire through. Worst comes to worst, you have wasted two minutes and will have to spend more time hunting one down.
This is another example of why I cannibalized a bunch of gear years ago, little things like a ferrite bead (that don't age/decay unless there is a fault) where it's more time to hunt down and more in postage than it's worth.
