Hi. I have to state that my abilities are limited to just being able to solder two wires together and taping them up. So everything has to be basic. I have a Laser cutter and before I even got to switch it on, somehow the plastic insert on the USB socket failed and became lodged in the plug. Without noticing i tried to fit the plug and all the pins bent. I have purchased a new socket, but I do not have the skill to remove the damaged socket from the control board. I have cut the top off the socket and i can identify the pins and match them to the new socket. I know this is a bodge but what is the best material to attach the new socket pins to the old pins. I assume the outer casing is an earth and will need to be attached to the new casing. I then have to work out how to keep the old pins from touching and a way to fit the new Socket to the board. If this is a crazy project, any other ideas please.
Platforms
Content
