Hello All.
Before I chuck it, I thought I would at least have a go at repairing it.
I have a late 70's sandwich toaster that needs a replacement cable that connects the upper plate to the lower cooking plate. It was working fine until there was a spark, a major glow from the cable, then nothing! You can see from the spring/coil protector where the break was.
Needs a bl*ody good clean but will only do this if it can be mended.
From the images, hopefully you can see the cable I need.
Please can anyone tell me what cable is needed?
Would be great to repair/recycle rather than going in the ground.
Thanks!
Thanks!
