Michael A. Terrell
Smitty said:80/20? 60/40? What kind of solder are you talking about? Eutectic
tin/lead is 63/37 and used in both hand and automated soldering.
Really? I want proof. If 63/37 is the only solder used, please
explain to everyone WHY there are so many different solder alloys sold
for electronics. I have NEVER seen a wave solder machine filled with
eutectic solder. 80/20 was used in all the wave solder machines I've
seen because it has a higher melting temperature and goes from liquid to
solid almost immediately.
I shouldn't have included the reflow process, because there is too
damn many low temp plastics used in SMD components these days. Earlier
boards only had the resistors, capacitors and semiconductors reflowed,
which could use higher temperature solders. Now there are lots of
crappy SMD connectors, pots and relays that require a lot more work to
create a workable reflow profile for the oven. Every board design has
to be evaluated, and a custom profile created for that assembly. We had
over three hundred profiles stored on the Heller oven when I left
Microdyne, all sorted by assembly/stock number.
They kept changing the paste solder for reflow, and replaced the two
original ovens with the computer controlled Heller so I couldn't keep up
with all the variations in alloys, ball sizes and fluxes. It seemed
like as soon as we found paste solder that worked right, we couldn't get
more of it, and had to start looking again. I know that the solder I
used for rework was .015" 60/40.
http://www.kester.com/en-us/technical/alloy.aspx is a chart of alloys
currently available from Kester. They list 13 various tin/lead alloys.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
