Remote control electric motors
Not really any more simple. The external relays are only necessary if the internal ones can't handle the voltages and currents And that is probably the case with the information you have provided. Unfortunately most of the cheap remote receivers don't provide that spec. So just assume that you need the external relays, and choose them to meet you 12vDC and 110VAC needs.
Ken
For the 1hp motor quoted and the fact that it will be on full load continually and the fact that the motor can draw 4 times or more full load current at startup, then a contactor would be more suitable as explained earlier.
The exception may be with the motor, depending on size, requiring a contactor which would be driven by the wireless relay.
yes it would be at full power the entire time that it is on.
