Remote car start via phone?
Bob Worthy
John Durbin said:
Are you an idiot? Starting the engine of a car with an automatic
transmission DOES warm up the transmission also... look it up - start
with "torque converter".
JD
John......John......John,
Calling people idiots will only put you in a special category, here in this
NG, labeled "RBL and his thousands of new found friends". You will last
longer if you don't make that file.
Jim
Likely he doesn't realize he's cross posting.
mikey
I'm sure the engine warms up everything connected to it sooner or later. My
postion is that everything should warm up at the same RATE. Not a good idea
to have a warm motor pushing a cold car, wheel bearings, axle, dif, tranny,
whatever. If it's too difficult a concept for you to grasp, that would make
you the idiot. Torque converter? hahaha, well, at least you can spell it.
JD
G
GregS
What. The only thing I can think of good, is warm tires, and
you can't warm them up just sitting there.
I did mention a cople of times, my transmission opperates much better after
the initial warm up procedure, just idling in the driveway.
greg
Matt Ion
whatever.
So either you take off right away so you have a COLD motor pushing a cold
drivetrain, or you let the thing warm up for half an hour.
I see no logic at all to your "position". WHY is it "not a good idea to have a
warm motor pushing a cold car, etc..."?
My answer to ALL this silliness is again to point out that almost every modern
car manufacturer recommends a start-and-go procedure and not allowing the car to
warm up more than 30 seconds in normal circumstances... seems to me they know a
damn site more about how their products will best respond than any of the
pundits in these groups.
G
GregS
to
i wonder how many of the executives of the car companies have remote start??
greg
mikey
whatever.
have a
modern
car to
know a
Your answer is the same as mine. I might go a step further and suggest
warming the fluids
is a good idea, certainly better than idling the motor but I'm saying the
same thing,
start everything working at the same time, take off, just take it easy and
all gets warmed up
at about the same rate.. but then again, its JUST AN OPINION.
