Peter Hucker
I need to make a relay switch on 1 second after a 12VDC line comes on, but switch off immediately the 12VDC goes off. What's the best way to do this? If you need to know why I want this, see the paragraph below:
I have a solar power setup and wish to switch the load between the invertor output and the mains supply. Currently I have a relay with a 240VAC coil which does the switching based on the output of the invertor. It doesn't work too good - the invertor output falls a bit as the battery gets low, and the relay starts jumping back and forth. What I would prefer is to use the 12V signal from the solar regulator (which is on whenever the battery is ok (and is what switches the invertor on). However I need to wait at least 1 second before moving the load to the invertor, as the invertor takes a while to start up.
