References for PIC microcontroller programming for sensors
Shaddy Daddy
Does anyone have any references for PIC microcontroller programming
for sensors (ie such applications as light detection /laser detection)
Thanks!
L
Luhan Monat
Thanks!
Shaddy,
Sounds like a no-brainer to me. Just connect the sensor to an
appropriate load resistance and feed an a/d input on the pic. You
should find lots of reference listings for using the a/d on Microchips
website.
John Fields
Shaddy,
website.
Robert Monsen
Its output is a square wave, so instead of the A/D, I'd put the timer into
'counter' mode, use the timer input pin to count ticks for some interval,
and then read out the result from the timer register. Alternately, a
frequency to voltage converter IC would work to transform its output into an
analog voltage, so you could use the A/D.
I'm guessing you were just pointing out the limitations of using the A/D for
every sensor job.
I agree.
Regards,
Bob Monsen
W
Wouter van Ooijen
How would you connect something like a TI TSL245 to a PIC's ADC input?
It has a frequency output, so I'd google for 'pic frequency meter'.
Wouter van Ooijen
http://www.voti.nl
PICmicro chips, programmers, consulting
