The 2100 turns on with A relay working. Power light goes to green. No audio output.
I checked the transformer, large filter caps, full wave bridge rectifier, and these were all in working order. I checked the transistors around the B relay. All appeared to be ok. B relay does not activate with the delay after A relay. I see no need to check the dc balance or idling current at this time. Which transistors on power board or protection board might be bad? All fuses are ok. I need help please. Tr601 and Tr604 act funny when I check collector to emitter and collector to base. Could it be the bridge rectifier on the power board? there are only 4 transistors on the power board but, I have not tested these yet. I know I sound like I am kind of nuts but this thing has driven me there. I have another one that does not power up either. But it does not come on at all. I checked the transformer on this one and it was ok. I really need help with the first one.
Does anyone have suggestions on which capacitors (audio grade) would be best on the power board, preamp, and amp boards? I looked at nichicon but I am not sure which one to use where. the unit is fairly clean and I am getting ready to give it the works for cleaning.
thank you.
