I just setup a Raspberry Pi to read the voltage being produced from a Solar Panel using an MCP3008 and following Adafruit's tutorials.
Anyway, one concern from the data sheet is that the ADC can operate max with 5V 500 micro amps.
If I'm reading it right (and so far ADC is still working) currently the solar cell indoors (under yellow incandescent light) is producing 1.49V at 70 micro amps. The solar cell is rated for 5V at 100 milli amps
What do I do when it actually gets sunlight and gets past 500 micro amps?
I think I'm supposed to use a 10K resistor, but I'm not sure what that means with regard to the measured voltage...
V = IR
but I don't know what that means with respect to the context
Right now when taking the two values 1.49V at 0.00007A = ~ 21.3K Ohms... what does that mean? Is that right?
So with regard to limiting the current to a max of say 300 micro amps "to be safe" what do I need to do? (read some books) haha
Thanks for any help
V = IR
Thanks for any help
