Re: Liability & responsibility of electrician?
  • Thread starter William Sommerwerck
Doug Miller
No, they do not.
I posted the law showing that it *is*. Not my fault that you're too stupid to
understand it.
Which does not.
Yes, it does. Not my fault that you're too stupid to understand it.
No, they do not. In the very citation you quoted it states that it is
not a felony.
This is the last time I'm going to explain it: simple possession in Indiana is
a felony if the amount is over 30g, or if it's a second offense. The text of
the law itself, and the URL at which you can read it for yourself have already
been posted. Not my fault that you're too stupid to understand it.
U
UltimatePatriot
In either case, it is no longer simple possession, idiot.
Doug Miller
Of course it is, you fool. Read the law! It says "possession". Possession with
intent to sell is an entirely separate offense.
In any event... I'm done. It's pointless to continue trying to explain this to
you, since you are clearly far too stupid to comprehend the explanation.
Bruce L. Bergman
Ungrounded Delta configuration, you total fucking retard. Yes, it was
208 volt per phase.
They might well be supplying 208V Ungrounded Delta if the original
tenants in that industrial park had hundreds of old machines built to
run on it. Like an army of old Swiss Screw machines cranking out
aerospace fasteners for the Space Race.
If they ask for it, and pay a bit extra for the special
transformers, the utility can provide practically anything you want -
but that's certainly NOT the norm nowadays.
When you hear hoofbeats, you expect Horses - that's a Zebra.
Most industrial gear that takes multiple voltages and is rated for
operation on either 208 or 240V does a lot better at 240V.
You don't see much at all that insists on taking 208V Only. And a
Buck-Boost or three for the individual machine is a lot cheaper than
getting an oddball feeder voltage from the utility.
--<< Bruce >>--
Archimedes' Lever
Wrong. WE had it installed.
We build power supplies, and we build them to spec (built).
So a customer wanted that input, so we put that in our Lab.
Not only could we work with that voltage, but we could also built and
test units that required more than standard service provisos.
Also, I do not believe that it is "Oddball" in El Cajon, CA.
U
UltimatePatriot
Thank you for your admission that I was right.
You're a goddamned idiot.
In the seventies it was decriminalized, as in NOT a felony. So it
pontificates your fucking error, despite you being too goddamned retarded
to see it for the PIG blinders you have been wearing all your life.
Archimedes' Lever
So because a Leftwing extremist is now president, the Feds are going to
go away from the long term enforcement of felony drug laws.
No, dumbfuck. What will more likely happen is that it will be removed
from schedule one, making the laws of every state null and void.
You must know what null and void means, considering that your pathetic
life has had a null and void effect on the rest of the world. Although
all the folks lives you fucked up over the years with your pig abuse
likely had a negative effect.
And he is not a left wing extremist (left wing is not one word, you
retarded twit), he is a Chicago Total Retard. You are just a nameless
total retard.
U
UltimatePatriot
So how long ago did you really start blowing dope as hard as it appears
you are doing now? Its obvious that its effected your brain
centers..and not for the best either.
Pity
"blowing dope"? You should at least attempt to use actual language,
dumbfuck.
And your capacity to judge appearances hovers at nil.
I work in national security, you?
Oh that's right... your 'brain centers' are all muddled by alcohol,
and a retarded PIG bastard senility.
You were "not for the best" the day you got started, punky piggy.
U
UltimatePatriot
And you are a stoner.
Yes, and a proud, productive one at that. Whereas you have
accomplished exactly nothing that makes the world a better place in your
pathetic punky piggy life.
Worthless,
Pigs are all fucked in the head because they think that all other that
are not pigs are 'worthless'.
We all know who really is worthless, "Gunner" Bwuaahahahahahahaha!
You are pathetic.
I'll bet that my SAT score is higher than yours.
and probably unemployed..
Nope. I work for the big boys.
or a
dish washer at a cheap restaurant.
You again show how truly pathetic the punky piggy mindset really is. Is
that a profiling technique that your fucked in the head California Police
Academy trained you to do, boy?
Makes us even doesnt it....ROFLMAO!!!
Except that you are wholly wrong. I have done more in the last year to
make the world a better, safer place than you will in your entire,
pathetic, punky piggy life. Laugh all you want at that fact. Oh that's
right... you retarded fucks run from facts because they contradict your
reports.
U
UltimatePatriot
Son..you may wish to reconsider that bit of spew you just blew out your
ass.
If you ever decided to take on Mr. Miller...your days posting
buffooonery on the internet would end permanantly within a few moments
of the meeting.
Just a heads up. Shrug..
You're a goddamned retard and so is he. No shrug required for that tid
bit to be obvious.
Archimedes' Lever
It is in MOST of So. California, hell....most of the Western States...I
cant speak about a shithole like El Cajon though.
Gunner
You never cease to prove to all readers that a PIG is a PIG is a PIG!
Do you always have such retarded views about those around you. boy?
You belong at the bottom of a "shithole".
You are about as unamerican as it gets.
U
UltimatePatriot
True enough..and adding copious amounts of Cannabis Sativa to their
brain cells simply makes them worse.
Im glad to see you are able to see your flaws.
You are an idiot. And a pussy as well.
I hope you enjoy your unamerican retarded pig senility. That is all
you have coming. I hope your years are over soon.
I curse you. Now, your shit is weak. You are among a very small list,
none of which still remain. Expect that chest ripping heart attack to
grip that little pathetic life you have soon.
Ever see the movie "Thinner"?
Richard Cranium
bit to be obvious.
Temper, temper Archie. Remember, uncontrolled hypertension is very,
very dangerous, especially to blacks.
Mr.Eko
Your problem, Cranium, is that not only are you so retarded that you
stalk people in Usenet, you are so retarded that your assessments are
always ass backwards as well.
I do not have any problem with my temper (you do and your posts prove
it). Still stalking, after all these tears, I see. You're still crazy
as well, Cranium. The therapy failed. Your only solution is to eat ten
of the Thorazine tablets at one time. Bwuahahahaha!
I am not experiencing any hypertension, uncontrolled or otherwise. You
seem to be a bit antsy since I told you that your mother should be
imprisoned, however.
I am not 'black', not that a total retard like you could have enough
brain capacity to tell anyway.
Now **** off and die, you pathetic little circus flea.
U
UltimatePatriot
Compared to you, cupcake..Im another Einstein.
Said the total retard that doesn't even know how to properly place an
apostrophe!
Bunk! Bwuahahahahahahahahahahahahahaha!
U
UltimatePatriot
Pushing a broom at some Homeland Security warehouse is hardly "national
security" so you exaggerat terribly.
You're an idiot, and you are the only one here that wanders from
reality.
U
UltimatePatriot
Good job of breaking the legand!
Gunner
The word is legend, you total retard.
Thanks for reinforcing folks' knowledge about how dirt dumb cops are.
