Mike Swift
billmcf said:One great feature of the Honda EU2000i is that the outputs of two
generators can be paralled to double the output power. The second
generator's inverter automatically synchronizes to the first generator,
and everything works.
I've always wondered whether three (or more) EU2000i generators could
be paralleled for even more power. On the surface, it seems like it
ought to work. Since the inverter is able to synchronize to a 60 Hz
waveform that is present at startup, why would it matter whether that
waveform was generated by two inverters rather than one? On the other
hand, could the third generator introduce instablity into a control
system tuned for two gnerators only?
Any thoughts?
I'm not suggesting that anybody try this, just trying to stimulate some
on-topic discussion.
From my experience in the U.S. Navy paralleling generators with
mechanical governors is very common. The only requirement is that all
generators on a bus must have the same droop setting. Droop is the
amount the generator frequency will drop as load increases. Each
generator will then put out the same percentage of its capacity as load
increases or decreases. Voltage control for each generator is used to
control the reactive power. You do not want high circulating currents
between generators that just wastes energy in the wiring.
As the Honda EUx000i models create the AC from the rectified output from
an alternator that runs frequency wild it's micro-controller does all of
the work of controlling power generation. From Honda's owners manual it
appears that the 'paralleling' kit is a junction box that takes the
outputs from two units and ties them together. Control to keep the two
inverters in sync is through the 'extra' cable in the paralleling kit.
If there are two control cable connectors on each generator they
probably have the capability of daisy chaining the control cables, and
the software to handle n paralleled generators. If there is only one
control cable connector on each generator the software would probably
not know what to do if it found it was talking to two or more other
generators.
