Jeßus
I doubt noddys might be described as tight if it's anything like his
comprehension levels
You're a poof.
You're a poof.
Heh
I don't think he can go for more than a few moments without bringing
chocolate wizz-wangs into the conversation.
Clearly there's a problem there
Tell us again who is it that has a favorite saying that includes "until
he spat/spits on your back"?
This is just flat out wrong. Most servers will drop IGMP packets (PING
requests) its means nothing. And before you say it, trace route uses
IGMP and will also drop the packets despite recording the first few hops.
The only way to know if the server is alive is to telnet. Open command
prompt and type, "telnet news.bigpond.com 119" no quotes.
I pinged it and it tried 4 times then said timed out, I then telnettedJasen said:actually ICMP
I use tcptraceroute when I want to know what's going on with traffic
pointed at a particular service, it uses TCP packets.
that won't tell you if it's alive if it's unreachable, due to some
sort of routing error or firewall. tcptraceroute will tell you where
your packets are reaching, this information is potentially useful to
the people who need to fix the mess.
Noddy said:Everything.
What would be a legitimate example of competition actually making
something worse?
D Walford said:I suppose it depends on what sort of service is most important, IMO
Telstra's mobile phone service shits on all the others because it has far
better coverage, the fact they are a pita to deal with is a secondary
issue.
None of the telcos provide good service but at least my Telstra phone
works in locations outside a major city long after all the others have
given up.
F Murtz said:I have a second phone with a vodaphone sim which cost $2 and $20 recharge
for 12 months the whole lot discounted 10% (although you have to put up
with vodaphone coverage)
Dechucka said:my phone cost $49 all up, it is prepaid my credit expires in 2115
It probably means the mx records reflect what previously existed butI pinged it and it tried 4 times then said timed out, I then telnetted
it and it said could not open connection to the host on port 119
Does this mean the bigpond news server server exists but not working,
just need ammo when the case worker finally gets back to me.
being down the server wont respond in spite of the mx claiming otherwise
Gas, electricity, water, public transport, telephone.... do I really need to
go on?
I have just recieved an email from bigpond giving detailed instructions
on how to connect to bigpond ng so it appears that the stories on its
demise are exagerated. I would post the email but it has an instruction
not to repost.
I still can not recieve it but that is probably a problem between
seamonkey, my modem and bigpond server,I think it needs my password but
I can not figure a way to make it ask for it.
not to repost.
The last time this happened, I could not access newsgroups using Outlook Express via Bigpond. For years I could, then one day I couldn't I waited for a few weeks and then I tried Bigpond "Technical Support".It took hours and I was shunted back and forth between barely literate teenaged girls who didn't have the faintest idea what I was talking about. They were ignorant and stupid and rude, they had never heard of Newsgroups but knew there was no such thing and the idea that I had ever accessed them using Bigpond was preposterous. They were unanimous in the sure and certain belief that it was all Microsoft's fault, whatever my complaint was. I was astounded that they had so little knowledge of anything to do with Bigpond. In a well-run society they would have
starved to death.
Some weeks later newsgroups re-appeared, and now they have vanished again. It is pathetic but brooding is fruitless.
It says could not open connection to the host on port 119
Presumably this means it is not working but would it not also mean that
it exists but not working as I assumed when I pinged it
Just tried that again, could not open, connect failedmark_ae86 said:Yeah unfortunately it doesn't tell you much. It confirms that you cannot
connect to it on the most basic level which saves any mucking around
with different newsreaders ect, this is now pointless.
Have you tried, telnet news-server.bigpond.net.au 119 ????
It seems that since my last post news.bigpond.com is now invalid.
However news-server.bigpond.net.au still resolves. Previously they both
pointed to the same IP.
Because eternal does not have binaries and telstra carries groups thatDavid said:As you are successfully posting here with some news
server, why are you trying so hard with Big Pond?
Even if they resumed their service, I would not bother.
