Sirs . . . . .
I'm just now tuning in on this thead, and thought that I had seen it started on another thread . . .but with it not having evolved into this higher state of analysis.
I had used the other info and was tracing circuit action in my mind and was step in step with what has now already been said here so I'll only inquire for info that I don't think that I have seen up to this point.
What is the high voltage rating on he main B+ supply caps? Those two big black 'uns.
I am seeing the secondary LVPS paltry requirements being derived from the AC line transformers right terminals over to the C7 filter cap and its diode to feed LV DC to the TL494 Switch Mode regulator IC and 4 bipolar drive xstrs.
Having the output of the 494 feeding into the 2 X 2 totem pole arranged bipolar 1015's and 1815's will give HARD full drive to the driver transformer located just above them.
ASIDE . . . .in looking back for the board layout . . . .
HEY . . . . there DOES seem to be another Ray Jefferson 155 post under Eduard, but his has the R7-R6 gate voltage divider resistors all flamed out.
I can clearly make out their color coding as being blackened-blackened-blackened.
So . . . . HE must, for sure, have at least a bad Q2 FET.
Between the use of both photos one can see the factory original cheap carbon film resistors that were used for the R7 (R572?) 1 K ohm and R6 (R472?) 75 ohm gate divider circuitry of Q1 and Q2.
Steve sez . . . . .
The purple circled resistor looks like it has gotten too hot (I don't know what it's purpose is).
Now back to that driver transformer, its isolated secondary is going to be needing a B+ drive level to the gates so I believe that overheated resistor is being the series source of that voltage.
With Gate to Drain and Source inter crashing, expect some collateral component damages.
John, you mentioned the AC across it (indicating a moderate AC ripple), but what DC B+ level do you have on either side of it ?
I consider its B+ source to be tied to the output of the second BIG BLACK main filter.
Far right bottom corner I am seeing the derivation of the heavy duty output source of the supply and I was ALSO querying the heat /discoloration in the past times across the vertical mounted BLUE film resistor (R20?)
It looks like Eduard's has fared better than yours..
I can account for the two secondary battery supplies, with them coming from the heavy Full Wave Bridge metal cases, down just below the heavy power fuse.
But I see no third source , but, look at the top right corner and see if that plastic heat sinked device might be just a 3 leaded full wave rectifier would then possibly be giving the third supply.
( Probably symbolized with diode polarity directions on its case.) Or, at the least, a part identifier number.
All for now . . .
ADDENDA: .
BUT I do see in the interim, while I was poking this up, that the thing go BOOM on its FWB rectified side to the FETS foil lines .
And I do see a 200V DClevel being mentioned now.
Did you test the FWB in the DVM's diode test function instead of its ohms range. Accounting for an open reading if using the ohms function
I feel that the foil paths opened up as fuse links.
But any DEAD short would be a definite failure.
My procedure for that NOW needed PCB foil repairpath is the fact that Hobby shops offer small sheets of copper foil for copper tooling .projects.
The thickness is even slightly thicker in gauge than the PCB foil . . .thats velly good !
I clean up the mess on the PCB and leave a clean gap and rosin up and scrape to tin the opposing ends and use solder wick to leave a final tinned smooth surface.
Then press a piece of clear scotch tape on top of the damaged area and trace over the foil and opened path outline with a fine blue Sharpie or 0 .5 mm drafting pencil.
Pull up the tape and stick over the foil and cut out the "patch" about 1/16 longer than the PCB foil gap.
Rosin up and tin both sides of the copper patch and move over to bridge the gap and reflow solder the
unions between the connections.
Pull out acid brush and MEK-Acetone-Xylene or alcohol and final clean the area of rosin, dry and burnish with a q-tip to a silvery shine..
The completed repair them impinges upon meeting Mil spec or NASA rework standards.
MUCH neater and original than an ole hunk of wire bridging the gap.
73's de Edd
