I developed an idea after toying with a two transistor flasher
The components are not completely spec'd I just wanted to get some opinions on feasibility. Taking the input from a normal closed switch with 0 VAC - call that the dry state for which I want a green LED to light up, the same switch will provide 3.39VAC when open - call that the wet state for which I want a red LED to light up. From the schematic, I believe I accomplished this goal if LED1 is red, when NC switch is open, 3.39 VAC will become rectified by the diode? (probably very dirty..) and lift the base gate to allow current to flow to ground lighting up LED1 and deactivating LED2(green). When NC closes, no flow through Q1 collector/emitter will turn base of Q2 on allowing current to light up LED2.
Did I get it?
I need help selecting a resistor for Q1/Q2 as well as help selecting appropriate transistors for this switch.
Thanks in advance!
Did I get it?
Thanks in advance!
