G
Geoffrey W. Schultz
I have a Furuno 1621 MkII radar that I've never been happy with. At this
point I believe that the radome has basically failed and I'm planning on
replacing the entire system.
I think that I'm going to replace it with RayMarine C70 system which
provides a radar and chartplotter. This will be compatible with my
Autohelm autopilot and this will provide a redundant chartplotter.
I've been pondering the differences between a 2KW radome and a 4 KW radome.
Based upon the litature the 2 KW unit provides 24 nm range vs 48 nm range.
This doesn't seem to really matter as the radar is only mounted about 10-12
feet above the water on a radar mast and the radar horizon to a 50' high
target is only 14+ miles. I've been told that the 4KW is very helpful in
dense fog (not applicable to the Caribbean where I spend most of my time,
but would be useful when I return to New England) or heavy rain and that it
also provides better separation of targets.
My typical use of radar is at night where I have the range set to about 8
nm or to watch for squalls, where the extended range would be useful.
There's a huge difference in cost between the two. The 2KW unit runs
around $900 and the 4KW unit runs about $1600. Based upon my usage and
setup, is the additional cost worth it? Are there other things that I
should be thinking of?
Thanks, Geoff
Thanks, Geoff
