I was wondering if anyone can help me with this situation. I have a 12V DC Motor. It will be powered by a 12V power supply, no batteries involved. It will be hooked up to a switch. The function I want to achieve is as follows:
When the switch is flipped one way, the motor spins clockwise for "X" amount of seconds, then stops. X being a defined number that can be programmed or controlled.
When the switch is flipped the other way, the motor spins counterclockwise for "X" amount of seconds, then stops. X being a defined number that can be programmed or controlled.
What would be the easiest way to accomplish this function? Preferably off the shelf components that you can buy, but I am open to ideas. Here is the link to the motor: https://www.ebay.com/itm/500-RPM-Ho...=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Any help with this in the right direction would be greatly appreciated. Thank you.
