Platforms
Content
A bit more information that may or may not be relevant. I tested the DC supply to both channel one and channel two output transistors. The reading going to channel one output transistor was 1.18 and reading to channel two output transistor was 2.77.
Your numbers 1.18 and 2.77 cannot be the supply voltage of the stereo amplifiers that produce 50W into 8 ohms. Their supply will be at least 60V or more than plus 30V and minus 30V.
What I tested was the two wires (blue and white see the attached photo) that go directly to the output transistor on the heat sink. I disconnected the wires from the output transistor and then turned the amp on and connected each wire to my multimeter on the auto DC voltage setting. Channel one, which does not get hot, had the reading of 1.18, channel two, which gets hot, had the reading of 2.77.
By each amplifier do you mean channel and channel two?Can you measure voltages as requested.
Please bear with me, I am just learning about how to do this. I have found the ground rails on my circuit board, but I do not know where to put the leads from my voltage meter.OK, the PSU section first
you need to check that those + and - 37V DC rails ( on the right of the diagram) are there and correct for each of the channels
Ok, figured how to test the + and -37V DC rails. They are both running at -35 and +35 DCVPlease bear with me, I am just learning about how to do this. I have found the ground rails on my circuit board, but I do not know where to put the leads from my voltage meter.
Voltage for power transistors in quiessent state:Can you measure voltages as requested.
