If a circut calls for a 10k resistor and you have r1 10k on the lower end of
the tolerance scale 9.6 k should you add another resistor to bring it to 10k
or just leave it ??
In most cases, things will work fine as long as the resistor is within
10% of the required value (often even 20% will do).
Where greater precision is required, the schematic/parts list will
call for 1% resistors. In such cases, the absolute value is usually
not too critical, but the ratio between two resistors is - for
example, in setting the gain of an opamp, the ratio of resistor values
matter - if the design calls for 10K and 20K, 9K and 18K should have
the same effect.
Of course, you also have to consider the accuracy of your meter before
you worry too much - if you measure a bunch of 10K resistors and find
that they are all around 9.6K, your meter is probably reading low.
Peter Bennett, VE7CEI
peterbb (at) interchange.ubc.ca
new newsgroup users info :
http://vancouver-webpages.com/nnq
GPS and NMEA info:
http://vancouver-webpages.com/peter
Vancouver Power Squadron:
http://vancouver.powersquadron.ca
