lbudney@pobox.com
Hello,
I recently got an ADUC831 microconverter board, and am interested in
experimenting with DSP applied to an audio input and/or output. A
friend who is knowledgeable about these boards recommended "passing
audio input through an op-amp to protect the board."
His meaning appears to be that I should connect my 1/8 in. jack to an
op-amp, and the op-amp to the ADC input, in such a way that if I
should inadvertantly overdrive the board, the ($1.50) op-amp will blow
first and spare the ($70) board. IOW, that I should use the op-amp as
a fancy fuse, and possibly as a clipper circuit at the same time.
Is that a standard practice? Can anyone offer pointers on using an
op-amp in this way? Alternately, can anyone recommend a better
approach?
Thanks!
Len.
approach?
Thanks!
Len.
