ah sorry,my transistor is 2n2222a!
then if i understand well(if something is wrong say me):
-the resistor at the base must be calculate with a colector current=0.3A,yes?
so 0.3/160=0,001875( minimum current to get saturation) and the resistor at the base must be maxium 6V(output 555)/ 0.001875=3.2K(maxium value to get saturation)
-and the cut-off zone the voltage across my motor is 0.7V (about the diode in parallel),and the saturation zone the voltage across my motor is (7-1.4)*duty cycle ?
so if all this is correct should it works well now??
