I was wondering if anyone had knowledge in PWM control and could help me interface an off the shelf controller with a 0-5v pressure sensor to create a constant pressure pump controller. I was looking at this controller, a 15A controller with POT or 0-5v input
http://www.criticalvelocity.com/products/datasheets/cv-spd-2115e.pdf
and this 1 bar 0-5v linear pressure sensor
http://www.aemelectronics.com/1-bar-15-psig-brass-sensor-kit-1179
I'm not quite sure how to connect the two while allowing an adjustment to set the desired output pressure of my pump. For instance.. if I wanted to maintain 170kPa ~10 psi this would be about 3.1v output from the sensor.. what else would be needed? some sort of amplifier I'm guessing to keep a narrow pressure range. Any input would be greatly appreciated. Thanks
