I've been designing a circuit to control a small DC motor which is attached to a butterfly valve. The motor assembly is completely enclosed and has some sort of logic governing the full open stop point and full close stop point. There are hard stops on the butterfly valve that once the motor/valve does it's learn function, it comes to a slow stop before reaching the stops to prevent damage of the motor. So I would assume there is some type of feedback to the motors control unit when the valve reaches the hard stop in both directions.
I've been going off the assumption that the signal wire to the motor/valve enclosure was a simple ground signal. It appears that the motor/valve is designed to operate off of a PWM signal
, should have checked that right from the get go I know.
I can operate the valve with no problem sending the motor/valve a ground signal, the issue that I keep running into is the motor/valve does a "relearn function" of the stops every so often. I'm pretty sure the enclosure is potted, so gaining access to the control board is probably out of the question.
Is there any reason why a constant ground signal would work fine the majority of the time and only sometimes have the valve reset itself? I am unable to replicate the problem consistently which is the part that is bothering me. I have the valve and my control circuit sharing the same ground also.
