Pure Sine Wave Inverter Question
L
Len Krauss
From what I gather a microwave oven operates much more efficiently (less
power, faster cooking) running on pure sine wave. I understand there are
also some other types devices that either require or benefit from pure sine
wave power. In view of the premium price of pure sine wave inverters, I was
wondering if it's worth it or even necessary. For instance, if it used say
25% less battery capacity that would be important. Can anyone comment on
this and other considerations for selecting a pure vs. modified since wave
inverter for onboard use?
Thanks,
Len Krauss
chuck
Hello Len,
I don't think the advantages of pure sine wave inverters
really fall into the category of efficiency as you've
suggested. Some appliances will not work at all, or will
work poorly, with less than pure sine waves. Whether to pay
a price premium for a pure sine wave inverter usually
depends on that consideration, rather than on anticipated
savings in cost or energy, which are not likely to be
noticeable.
There are also modified sine wave inverters that provide
"purity" between a pure sine wave and a square wave. These
may be a better buy, but your choice should be dictated by
the appliances you intend to operate.
Here's a web site you can start with. Do a Google search on
"pure sine wave inverter advantages" to learn more.
http://www.q3wholesale.com/Resources-sinewave-guide.htm
Sine Wave Guide
Good luck.
Chuck
Doug Dotson
Probably, but a microwave runs so little that efficiency is not likely much
of an issue.
sine
wave power.
True. Some TVs, VCRs, DVDs, etc run better off of pure sinewave. In my case
none of these devices seem to care so my modified sinewave inverter is fine.
Try a modified sinewave inverter and see how it works. Only switch to
a true sinewave unit if you have problems.
I'm not sure that effeciency is the question. Some devices do not run as
well
on modified sinewave. For example, my microwave does run cooler so has
to run a bit longer. Other than that, I don;t notice any larger draw for any
given device.
Use a pure sinewave unit if any of the devices you are trying to drive have
problems with a modified sinewave unit. I wouldn;t be too concerned about
efficency.
