JosephKK said:
I'd already considered laser pointers but, as I explained
elsewhere, I anticipate problems with on-site alignment - four
narrow beams hitting tiny sensors at a distance of more than 10
ft over uneven ground. And once aligned, both emitters and
sensors would have to be fixed firmly enough against accidental
knocks and vibration.
It is much easier to keep all the electronics together in one place
and
just fold the light path. The self-oscillating system I have
described in another post will work perfectly well over a double
10ft path in bright sunlight (as long as it doesn't fall directly on
the sensor).
Use a reflexor at the far side and keep the source and detector
close
together in the same box on the near side. Test a few
easily-obtainable reflexors (such as number plate background
material and the reflectors for bicycles and the sides of lorries)
to check that they work at your chosen wavelength.
Ah yes, the three corner reflector trick. Reflects the incoming beam
parallel to and adjacent to itself. Then the detectors are adjacent
to the emitters and no wire to run and most alignment issues reduced
or eliminated.
Thanks Adrian, i had missed this.
This physical efect has a name that I suspect is good enough to
web-search on:
"corner cube reflector"
It appears to me that plenty of bicycle reflectors including most
other
than "aftermarket", some bicycle taillights, and some automotive
taillights use this principle.
In most vehicle-mounted retroreflectors (one more keyword), there is
at
least one area of clustered small-sizede corner-cube inits with "cell
size" around 3 mm IIRC, and depending on (successfully) that a
refractive surface towards the incoming light source (boundary between
air and plastic) refracts the incoming and outgoing light rays equally
so as to maintain retroreflective property of the array of "corner
cubes".
Many of these vehicle retroreflectors rely on arrays of small
"corner
cubes", whose surfaces are angled sufficiently close to parallel to
incoming light rays desired to be retroflected, so as to achieve great
retroreflection from air-plastic boundary via "total internal
reflection". That principle of physics has its presence being a
function of angle of a ray being incident to a boundary from higher
refractive index material (such as plastic) to a lower
refractive-index adjacent material (such as air).
There are also retroreflective objects marketed to cyclists (and
elsewhere) involving very small glass spheres made of glass of
whatwever variant has refractive index that favors a significant and
notable bit of
retroreflection. One thing that comes to my mind is "Scotchlite" (tm)
by 3M.
- Don Klipstein (
[email protected])
