"Jeff Liebermann is a FUCKING ****"
Pedantic
-adjective
1. ostentatious in one's learning.
2. overly concerned with minute details or formalisms, esp. in
teaching.
** More fucking, idotic pedantry.
Only thing this stinking POS is any good at.
** Go **** your mother.
( Snip more pedantic, fucking SHIT )
The question was whether the power
supply was defective, which in my opinion is more a matter of keeping
the output voltage within the specifications (with any load).
** More pedantic BOLLOCKS.
Linearity is usually +/- 1 bit or LSB. If it's a 3 1/2 digit cheapo
DVM, with a full scale reading of 1999, it probably has 10 bit A/D
converter.
** ROTFLMAO !!!!!
Wot a FUCKING MORON.
Regular DMMS do not use conventional A-D converters.
They use "dual slope integration " - ie an analogue technique.
The "digital" bit is the fucking display.
IMBECILE !!!!!!!!!!!
1 bit error = 20.0 V / 2000 = +/- 10 mv error.
For an 80 mv difference, there's a 40 mv uncertainty due to
non-linearity (+/-10 mv error for the no-load, and another +/-10 mv
for the loaded readings).
** Crapology.
The same meter is used and so the only error is the +/-1 bit display
uncertainty.
GO **** YOURSELF you STINKING PEDANT !!
..... Phil
