PSpice: Possibility to initialize flipflops randomly
Hi.
I'm currently working on a simulation of a digital circuit. In order
to find out if I really need power-up resets for all flipflops I would
like to perform some simulations with random initial states.
Can PSpice do this automatically? I only can find an option to switch
between 0, 1 and X state as inital state for ALL flipflops.
Regards,
Norbert N.
Charlie E.
Hi.
Regards,
Norbert N.
Sorry Norbert, but those are the options. Usually, you should use
'X', as this basically says that, until the FF is TOLD what state it
should be, it doesn't have a state. Most set them all to 0 or 1,
(usually 0) to not have to go through the trouble of initializing
everything.
Charlie
everything.
Charlie
Thanks for your response Charlie.
I know that I can force all FFs to 0 or 1 default state in order to
simplify the simulation circuit.
But I want to find out if I need initial resets in the REAL circuit
where I have to expect random initial FF states.
H
Helmut Sennewald
everything.
Charlie
Hello Norbert,
This will require that you set every possible combination as a start
condition.
It's useless to rely on what a programmer of PSPICE has decided for the
default at startup.
Best ergards,
Helmut
