Active8
hi:
there's nothing about this in the manuals. is there a way to specify two
parameters to be swept? for instance, the capacitive divider in a
oscillator feedback loop, sweep both.
alternately, is there a way to specify a component value as a function
of another parameter or another component (e.g., an R-2R ladder where
you could just specify R1 and have the others calculated from that value
which would be handy in a param sweep.)
i can't delete properties from the PARAMETER properties (ORCAD thing)
either. and PSpice docs, refer to "NAME=" and "VALUE=", neither of which
show up in Orcad's property sheet, rather you see "Reference", "Value",
and any user defined properties which are the ones i can't get rid of.
thanks,
mike
thanks,
mike
